04 Disco II Won't Start
Old Dec 15, 2011 | 12:54 PM
stlrover04's Avatar
Default 04 Disco II Won't Start
Hi all,
The past week or so the disco has been acting up when starting. It seems that the problems up to this point have only existed when I turn it off for an hour or less then try to start it again. If it sits for a few hours it fires right up. The symptoms remind me of a dead battery but the battery tested fine. Lights work, etc. When I attempt to start it the lights dim and it hesitates with some obnoxious clicking then the it starts up. Now it won't turn over or click or anything. Again, battery seems fine and lights all work when this happens. I am leaning toward the starter. Thoughts?
If thoughts are starter... is this something I can replace on my own? I am an amateur mechanic at best but enjoy working on my disco so willing to try if it's not too complex.
Thanks for the feedback!
Old Dec 15, 2011 | 01:23 PM
hilltoppersx's Avatar
crank position sensor.
Old Dec 15, 2011 | 05:03 PM
stlrover04's Avatar
Replaced crank position sensor in June and seems different symptoms. Knowing just replaced any other thoughts?
Old Dec 15, 2011 | 05:19 PM
jafir's Avatar
Might be kind of hard to do because of the heat shield, but what it won't start, if you crawl under and beat on the starter, will it start? If so, then it might be time for a starter.
Have you checked all of the power and ground cables?
Also, it's possible for a battery to be bad/weak enough the starter won't work, but all of the lights do.
Old Dec 15, 2011 | 05:33 PM
SolbergFanBoi's Avatar
All good suggestions for sure... If you try hammering the starter, just make sure to do it while cranking it. I don't think the OP mentioned that, probably assumed you knew that
Old Dec 15, 2011 | 06:13 PM
boris_gti's Avatar
Just my input......I just did my starter 3 days ago. It was so done that even with hitting it, it still wouldn't turn. Solenoid would kick out, but that's about it.
Old Dec 15, 2011 | 07:46 PM
Your symptoms point to a starter. If it was crank sensor, engine would turn over but not fire. First check battery cables and cables on the starter, would not want a dirty connection to cause all this. Starter comes out, but usually it is easier to get to it with a couple of extensions from in front of the axle. Wash out the metric allen cap bolts with solvent / brake parts cleaner, so you can get to the bottom of them. PITA if you strip them.
Old Dec 15, 2011 | 08:03 PM
boris_gti's Avatar
You gotta take off the heat shield. One bolt (10mm) from the opposite side on the engine mount. YOU DO NOT NEED TO TAKE OFF THE EXHAUST MANIFOLD!!! Wiggle it around a bit and it will come off.
Disco Alan
Nov 21, 2014 09:21 AM
toad2
Jan 17, 2014 09:19 PM
Mountain State Rover
Jun 29, 2013 02:06 PM
dmatranga
Feb 5, 2013 12:27 AM
vtec2403
Jan 30, 2013 05:27 AM
