04 Discovery II Misfire
Old Aug 21, 2016 | 10:10 AM
allshookdown's Avatar
6th Gear
Default 04 Discovery II Misfire
Good morning all!
I bought this 04 Discovery II a back in June. Drove it for a month or so and noticed that vehicle started running a bit rough. Took it in, had it scanned and it scanned a few misfires and a mixture adaption. I was told to start with the misfire. So, I changed the plugs and wires. Still ran crappy. Changed the Crankshaft Positioning Sensor. Still ran crappy. Last thing I changed now has been the coil pack. Still running crappy and now reading misfires on 3, 5, and 7. I am lost. Any help would be greatly appreciated!
Much thanks!
Old Aug 21, 2016 | 12:12 PM
disc oh no's Avatar
What was the mixture adaptation code for? Lean or rich exhaust?
Old Aug 21, 2016 | 10:43 PM
number9's Avatar
Purchase your own scanner, learn to use and read search form.
Old Aug 22, 2016 | 12:14 PM
6th Gear
The mixture is pretty rich. Like its getting choked out.
It is currently parked at the persons place that is working on it and he has a scanner himself.
Old Aug 22, 2016 | 01:54 PM
squirt's Avatar
Without specific codes, it's tough to diagnose over the internet. Recommend getting Pxxxx numbers for the codes and starting there. Your misfire issues seem to be isolated to the DS bank, could be a DS O2 sensor, head gasket, or many other things.
Old Aug 22, 2016 | 02:17 PM
6th Gear
squirt, these were the codes he sent me:
P0303 Cylinder 3 Misfire
P0305 Cylinder 5 Misfire
P0307 Cylinder 7 Misfire
P1300 No DTC Definition Found
Old Aug 22, 2016 | 05:37 PM
chubbs878's Avatar
Did you put all 4 bolts back into the coil pack mounting bracket? If any of them are loose or missing, you will sometimes get a misfire. This has been debated but was a problem for me one time.
Old Aug 22, 2016 | 08:29 PM
Charlie_V's Avatar
Unless you are losing coolant that is almost certainly a bad mass air flow sensor, based on what you have already replaced. Be sure you don't have old spark plug wires shorting first but it sounds like MAF shenanigans to me.
Old Aug 29, 2016 | 10:02 PM
6th Gear
I went and got some Mass Air Flow Sensor cleaner and cleaned it out. It started up and we drove it up to the garage so we could hook the scanner up to it. It read the same misfires as it did before and also had a new one on Cylinder 6. Well, then it wouldn't start. I ended up taking it apart where the air sensor is and it started up, ran for about 2 minutes (best it's been running) and killed. Was looking at ordering a Mass Air Flow Sensor being there is no coolant in places where it shouldn't be. Rather confused though.
Old Aug 29, 2016 | 10:45 PM
dgi 07's Avatar
Did you clear the codes....MAF troubles manifest themselves strangely on these trucks. How many miles do you have? And how did you clean the MAF?
Charlie_V
May 28, 2017 12:18 PM
BamaDisco2
Feb 4, 2016 09:27 PM
Gromeo
Jan 24, 2013 03:41 PM
lajilana
Sep 2, 2006 10:47 AM
Scott2747
Feb 8, 2006 12:11 AM
