04 Discovery wtf
Old Aug 28, 2016 | 05:58 AM
04DiscoMike's Avatar
Default 04 Discovery wtf
Friday afternoon I was running errands and all was fine... After stopping at cvs for 5 mins I got back in the truck and it wouldn't start. When I turned the key everything turned on inside the car except for the car itself.. It will not turn over just a quick noise and then nothing.. Anyone plz help
Old Aug 28, 2016 | 07:42 AM
Alex_M's Avatar
What does the noise sound like?
Also, when you say it wont turn over do you mean it wont crank or it wont turn on? That's a commonly misused term.
Old Aug 28, 2016 | 08:59 AM
It won't crank...I honestly can't describe the noise bc it's so quick..
Old Aug 28, 2016 | 09:21 AM
disc oh no's Avatar
It could be a bad starter or battery connection. That's probably what I would check first. If it just makes a clicking sound, it may be a dead spot in the starter motor. Maybe try tapping on the starter. Sometimes that will get it working again.
Old Aug 28, 2016 | 09:24 AM
It was the weirdest thing... No issues.. And all of a sudden the car just wouldn't start.. I checked the battery it seems to still have juice bc it's powering my radio and all other electrical **** in the car.. I dunno... I had to have it towed home yest
Old Aug 28, 2016 | 09:27 AM
It's def not a clicking sound.. But I will check the starter... Where exactly is that located?
Old Aug 28, 2016 | 09:29 AM
Best4x4's Avatar
Sounds like a starter to me.
Old Aug 28, 2016 | 09:30 AM
disc oh no's Avatar
How did you check the battery? I'm just curious because the radio and that kind of thing uses far less current than the starter. If you have no other way to test the battery, one thing you can try is to leave your dome light on and then try cranking the engine. If the light dims significantly when trying to crank the engine, the battery probably doesn't have enough power to turn it over. The headlights are really better to watch for dimming. Though keep in mind some vehicles shut the headlights off when cranking. So it's not always an accurate test.
If the lights don't dim at all, I would look towards the starter or power and ground to the starter. From your description, it sounds like the starter may be bad.
Old Aug 28, 2016 | 09:50 AM
I had a friend check the battery with a volt reader.. It read 12v and when hooked up with jumper cables from truck to truck it went as high as 13v... Is the starter on the same side as the battery? 04 D2
Old Aug 28, 2016 | 09:56 AM
Yes passenger side bottom of the motor by the exhaust pipe.
