'04 into '03 engine swap
Old Oct 27, 2009 | 08:25 PM
jkeving's Avatar
Default '04 into '03 engine swap
I have an '03 Disco w/ 120k miles and 2 cylinders w/ some coolant leakage. Rebuild is more than the car is worth but getting a used complete motor is way more reasonable. How bid a deal is it to r/r the entire engine and get the electronics to play nice together? Have done similar replacements in MG's, Porsches, etc.
Old Oct 27, 2009 | 09:02 PM
They are the exact same engine and engine management, pull out the old and drop in the new.
The truck wont know the difference.
Old Oct 28, 2009 | 10:55 AM
Do you know for sure that you have dropped a sleeve, if not, I would verify that before considering an engine swap.
Old Oct 29, 2009 | 07:21 PM
jkeving's Avatar
Mike:
this is the '03 disco that 2 years (37k miles) ago I was told the engine had not a dropped cylinder but some erosion of the material around the liner (#6) and that allowed coolant into the cylinder , the cooling system would get overpressure and drive out the coolant. Block was supposedly totaled (not cylinder head)
I did a sealant treatment which solved the problem and has lasted since then, but now #4 plug is starting to turn "orange" . REst of the truck is great, but don't want to go cylinder by cylinder with this.
So if i get a low mileage '04 how hard is it to do a swap?
thanks again
Red_Liner740
Dec 22, 2020 01:48 PM
bennyb43
Dec 11, 2013 08:17 AM
wanjman
Apr 27, 2012 08:58 AM
jlipper
Oct 15, 2011 03:08 PM
roverfriend
Sep 26, 2010 11:04 PM
