04 Rear sunroof part numbers.
Old Sep 16, 2023 | 12:40 AM
PD2004USSalty's Avatar
Default 04 Rear sunroof part numbers.
04 Discovery HSE 4.6l SALT VIN in case that matters. Rear motor pulled and tested working. Sunroof no leaks. Motor was connected but was not installed correctly as whoever tried did a quick job broke all the tabs to remove it and glued it back up afterwards also never used the original hardware to install the motor they used a deck screw in one hole and it was never tight so when I pulled there was alot of metal fibers chewed off the part the gear turns so not sure if that is no good or not . But for now I want to have the part numbers if anyone knows them for the track the motor connects too. I ordered the hardware 3 screws 2 torx and 3rd torx but looks brass and longer. I will try and reinstall this motor and hope the threads are not totally screwed up literally. And if I can install correctly I'll test if it's resolved or time to replace parts. If I can next week post a close up of the part I will. Right now its being used for a trip. I won't have access for a few days.
Old Sep 16, 2023 | 03:25 AM
Dervish's Avatar
This any help?
https://parts.jaguarlandroverclassic...nd/land-rover/
roverfogg
Jun 18, 2020 01:39 PM
Frank4
Apr 5, 2020 04:44 PM
Carolynsdisco2
Dec 6, 2017 06:37 PM
rickroverover
Jan 7, 2016 08:34 AM
mlelah
Freelander
Sep 3, 2011 03:02 PM
