04 slipped liner?
Old 10-02-2014, 06:08 AM
Sarge103's Avatar
Default 04 slipped liner?
started making a ticking knocking sound
Old 10-02-2014, 06:50 AM
redrover75's Avatar
I do not know, does not sound like one to me. Do you have the 180 degree thermostat in there? Have you been running premium fuel? What oil is in there?
Mine sounded a bit like that, changing all of the above made it run much more quietly. I would even try some MMO or similar to see if it clears up your valve train.
drowssap's Avatar
does the noise go away as you raise the rpm, at a some point the piston speed to over take the liner and it should quite down.
ive only heard one liner and it sounded like a rod wrap not a tick.
Old 10-02-2014, 06:53 AM
Sarge103's Avatar
I run 93 octane, rotella 15w40 with one quart of mystery oil, I dont know what t-Stat I have since I recently got it and haven't looked.
Old 10-02-2014, 06:54 AM
Sarge103's Avatar
The noise only comes when engine warms up. It goes away with raise in rpm.
Old 10-02-2014, 07:09 AM
drowssap's Avatar
so your running rotella 15w40 with one quart of mystery oil? why the MMO is just thinning the 15-40.
Old 10-02-2014, 07:13 AM
Sarge103's Avatar
that is exactly what the PO told me he changed the oil with 3 days before i purchased it he gave me the receipt.
Old 10-02-2014, 07:56 AM
drowssap's Avatar
i persoanlly would get rid of the MMO and refill it with 15-40 or 20-50 and see if it quiets down
Old 10-02-2014, 07:57 AM
Sarge103's Avatar
it just sounds more like a knocking than a valvetrain noise
Old 10-02-2014, 08:04 AM
RicketyTick's Avatar
RMT says to run water from a hose onto the side of the block to cool it down while it is ticking and if it stops ticking it is a liner. Then if you remove the hose and it warms back up again it will start back ticking. You need to hose it down below the exhaust manifold and above the oil pan on the side of the block. Turn the water down low and try not to wet any of your sensors or electronics if possible. You may have to try each side of the block if you are not sure which side it's coming from. If that stops the tick then buy a grey 180 genuine thermostat (link below) and see if that will cool your engine down enough stop the tick. I've never tried the hose down test but, makes sense and he says it works so I'm sure it does. I have replaced the thermostat with a 180 and did stop the tick but, may not work for everyone. It's worth a shot.
THERMOSTAT ASSY DII & FREELANDER 180 DEGREES FAHRENHEIT, PEL500110, RNQ028 - Rovers North - Classic Land Rover Parts
Quick Reply: 04 slipped liner?
