'04 T-Case Purchase...
Old 02-25-2012, 09:37 AM
kenk's Avatar
The shop that replaced my t-case said done carefully, they removed and replaced w/out droping the crossmember or y-pipe, but the exhaust from the Y back has to be removed. The t-case has to very-carefully supported while unbolted so it does not drop at all, then they said they were able to slide it backwardsto clear the Y. I also remember them saying something about to do it that way, the mounts had to come off with the t-case, and not left bolted to the frame.
  #22
Old 02-25-2012, 01:34 PM
bosshogt's Avatar
Originally Posted by yloDiscoII
Did you have any trouble removing the crossmember or the Y-pipe? Any tricks? Heat?
The bolts on the Crossmember are stupid. 10mm heads on large studs. So get a 10mm 6pt socket. Only good part is you can spray penetrating oil in the top of the threads by looking in the side of the crossmember. I used Seafoam Deep creep. I also used a breaker bar. I got all of them to turn except one...of course :0 ...so I have a set of craftsman head bolt extractors. they bit in and I was able turn it. I replaced all those bolts with stainless with regular heads. I also put anti-sieze on them.
I agree on not replacing the output bearings. If there is not excessive side to side play they are fine. Replacing the output seals might be a good idea though.
  #23
Old 03-01-2012, 11:49 AM
yloDiscoII's Avatar
Thanks for the tips guys. I'm going to go the "standard" route and remove the Y-pipe and cross member, so I'll be ready to extract/replace those bolts. I also grabbed new gaskets and studs for the exhaust as I've been told those tend to need to be replaced.
Any other tips?
  #24
Old 03-01-2012, 11:53 AM
yloDiscoII's Avatar
Thinking about having some "heat" hand for stubborn bolts. Would something simple like this work?
  #25
Old 03-01-2012, 12:52 PM
DiscoIIBrandon's Avatar
Default PB Blaster
PB blast every bolt a day or two in advance (so exhaust heats it up for you), and again before you start. PB has never let me down. Good luck.
  #26
Old 03-01-2012, 03:19 PM
yloDiscoII's Avatar
6pt - 10mm 3/8 drive socket - CHECK
Screw/Bolt Extractor Kit - CHECK
I love Sears gift cards
Now to pick up another can of PB Blaster....
wildhorses
10-19-2005 02:42 AM
kend500
06-19-2005 01:48 PM
Oceanboy
05-21-2005 11:52 PM
gatorfan91
02-18-2005 12:51 AM
Quick Reply: '04 T-Case Purchase...
