# 10 Head Bolt Torque
Old Dec 31, 2007 | 11:48 PM
sunshineking's Avatar
5th Gear
Default # 10 Head Bolt Torque
Had my heads redone for my 98 Discovery I and i am in the process of remounting them back on the block.
Can anybody describe a good procedure and tools/special sockets for tightening the head bolt #10( short bolt close to the firewall) to the specified torque?
I had all the bolts torqued to 20Nm first then 90 degrees but for the last 90 I can't really apply that much force to this specific bolt that is so close to the firewall and don't want to end up with a rounded head bolt..[/align]
[IMG]local://upfiles/9018/2C49FA0E8B57408B8B04686C1D09AFBC.jpg[/IMG]
Old Jan 1, 2008 | 03:44 AM
geotrash's Avatar
Default RE: # 10 Head Bolt Torque
Looks like the perfect place for a swivel socket extension or a universal joint extension.
Dave
Old Jan 2, 2008 | 10:01 AM
5th Gear
finally got both heads back on.Unfortunately that #10 head bolt on driver side-left cyl head got rounded in process so fo the last stage I was able to get it torqued to only about 40degrees instead 90..I will try to remove it tomorrow and pickup one from the local dealership...
- Any advise on how much torque do i have to put on this bolt /follow the same procedure -15lbs-90-90?
-Should I get a whole new set for this cyl head instead one bolt only since compatibility issues may arise with a different manufacturer than the other 9 bolts?
the quality of the aftermarket head bolts.. they're
notvery good at least the set I got. You can almost feel the socket rounding the head of the bolt during the last stage..
Not having another person helping you do the last 90 degrees of torque makes it very hard for one person so I removed the 2 rubber engine mount shock absorbers from both sides of the engine
( took me about 10 min for each side with the help of the engine hoist-jack and a block of wood works as well) .
Night and day difference once the engine is lowered a bit..you have enough space to work around the cyl head when you do the torque..
My 24" breaker bar was not long enough to have enough leverage so I used a piece of pipe and this way i can apply pressure down on the socket with one hand while rotating the bar with the other..
Impact sockets ..a must for this job....preferably a new or not abused socket..
[IMG]local://upfiles/9018/6C2E43D6CA8F4D29BA7CF8A7854CDD63.jpg[/IMG]
[IMG]local://upfiles/9018/8DA5058F4ABC40DEACDC9031B8C2BA27.jpg[/IMG]
[IMG]local://upfiles/9018/681356B399914A6EB00B914FA09279B6.jpg[/IMG]
Old Jan 2, 2008 | 11:28 AM
98roverguy's Avatar
When I did mine I did what I could with the torque wrench, and just tried like hell with a swivel socket to tighten it further. You have to sweat and use every muscle possible. That bolt was the toughest of them all.
Old Jan 2, 2008 | 06:52 PM
Tastang's Avatar
I discovered that the 90 degree turn put the bolts at about 85 ft/lbs. I used that setting on the hard to reach bolts and have had no problems at all. Good luck!
RicketyTick
May 30, 2014 09:01 AM
FlyingZebra34
Jul 6, 2013 04:07 AM
focusontheworld
Oct 21, 2012 01:00 AM
aublec22
Sep 16, 2011 07:27 AM
kraelo
Apr 1, 2008 12:02 AM
