11 Fault Codes - Discovery II
Old Jun 7, 2010 | 10:08 AM
hilltoppersx's Avatar
that is the correct part.
do you use a K&N air filter?
Old Jun 7, 2010 | 10:19 AM
Originally Posted by bocamar
Thanks for your suggestion, however, I replace the MAF 7 months ago...based on that what other issues could be?
Leave the MAF alone since you have no codes indicating a problem.
After you clear and run the truck again, give us the new codes that come back and then lets talk.
Old Nov 1, 2010 | 03:01 PM
bocamar's Avatar
Default P414 - Brakes
I just got this code P414 using a Hawkeye Diagnostic for LR.
I got the 3 amigos lights on my panel.
According to the scanner it is related to
Shuttle valve switch failure
Could someone help me here please
Old Nov 1, 2010 | 03:08 PM
read this http://www.landroverclubvi.com/abs-mod.html
Old Nov 1, 2010 | 03:10 PM
dcarr1971's Avatar
You should probably take a look at this...I believe it provides several options for you to address the shuttle valve issue.
Old Nov 1, 2010 | 07:14 PM
Your 414 is not ABS related but is a secondary air injection system switching valve "B" has a circuit malfunction.
As for not being able to read your 3 Amigos codes, what version of the Hawkeye do you have, I don't think the early ones could read it, newer one's can.
Old Nov 1, 2010 | 09:08 PM
bocamar's Avatar
Default P4114
Hi Mike, thank for your reply
The code is P4114 Scanner Used Hawkeye for Land Rovers http://www.roverparts.com/Parts/BA5070.cfm
Also, I have the P1590
Old Nov 2, 2010 | 08:51 AM
never heard of a 4114, but a 0414 is the SAI vacuum solenoid.
the 1590 will go away when you tackle the ABS issue.
Old Nov 2, 2010 | 04:26 PM
bocamar's Avatar
Default P4114 Hawkeye
P4114 Hawkeye
Attached Thumbnails 11 Fault Codes - Discovery II-img01361-20101102-1309.jpg
Old Nov 2, 2010 | 05:42 PM
oh 114 and its not a P code. Thats the ABS shuttle valve fault.
read this. http://www.landroverclubvi.com/abs-mod.html
