17 Codes...places to start?
Old Aug 13, 2012 | 04:02 PM
br0keit's Avatar
Hate to be the bad news guy but most likely you just had a bare wire on one of your o2 sensors. As i'm sure you figured out since its fixed, you probably blew a fuse (fuse 2). That fuse is for all of those parts that were throwing codes. It happens when a bare wire to one of them (or a failing component) blows the fuse, then they all go. You could have probably just fixed it with some high temp tape though if you had high mileage you still didnt do too bad by replacing the sensors as they were probably going out soon anyways. If it does trip again my bet is on a bare wire somewhere, find it, fix it, and you'll be in the hole $.05 for a piece of tape.
Old Aug 14, 2012 | 10:16 AM
TRIARII's Avatar
Either way he would have had to replace those O2 sensors eventually, so now that's one more thing he can check out off his service list as completed. Plus it should helo maintain his fuel economy.
Good work on the fix nevertheless, gonna say that 17 bloody codes all at once is crazy! Never knew that faulty O2 sensors could cause so much havoc! I think I'll go ahead and replace all mine just to be safe.
Old Aug 15, 2012 | 07:21 AM
lrsmith62's Avatar
Thinking on it....one of the rears had one of the wires sitting a bit close to moving parts...may have been worn thru as it did feel very limp. Both rears were ready to be changed...black as tar....but the fronts were probably ok...still, had the car up and went ahead and changed all. Engine runs so much better now...happy with the fix! Thanks for the heads up on looking for wires next time!
Now, on to the passenger seat lumbar bladder....not looking forward to tracking down this issue!
Old Aug 15, 2012 | 07:42 AM
Sometimes the RAVE electrical can provide an idea of what things look like and where connectors are. See attached for lumbar pump (C0974 connector).
File Type: pdf
Old Aug 15, 2012 | 12:00 PM
SiloMan's Avatar
4th Gear
lrsmith62 or anyone....just a quick question, please. Did you have to replace Fuse #2? If not, what would cause all 4 O2 sensors to go out at the same time. The reason I ask is because I'm trying to learn all I can.......Thanks everyone.
Old Aug 15, 2012 | 03:08 PM
br0keit's Avatar
If memory serves me (and i'm sure savannah will come in here with 100 page pdf on the chemical composition of each wire) I believe fuse 2 protects the o2 heaters. It doesnt protect the communication lines or power for the sensors, that is a different fuse.
Old Dec 24, 2014 | 08:35 PM
TRIARII's Avatar
Looks like im getting almost all the same codes so the first line of business will be replacing all 4 02 sensors.
04SSHD
Apr 11, 2012 06:20 PM
Jrock
Sep 21, 2008 02:57 PM
xavierf11
Dec 22, 2007 05:54 PM
Tink
Jan 23, 2007 07:08 PM
airmarc
Sep 10, 2005 10:47 PM
