1994 V8 Will Not Start After new Rotor Arm Fitted - Please Help
Hello.
My 1994 Discovery 3.9 V8i Auto started running lumpy on tickover a few weeks ago. It always started and didnt really run too badly. Today I had a look at the dizzy cap and rotor arm and they looked a bit worn, so I bought and fitted new ones, and now the engine turns over but shows no signs of firing.
When I took the rotor arm off, the mechanism below seemed to lift and rotated round but it seemed to only go fully down again in one position - is this normal? Hope I haven't put the timing out!
Secondly can anyone tell me the correct lead order on the dizzy cap just to make sure I have got everything in the correct order. I tried fitting the old parts and it wouldnt start either. Please help!! Many thanks, Matt.
RE: 1994 V8 Will Not Start After new Rotor Arm Fitted - Please Help
Oh great, and I thought a 2 min job would make it run better rather than knacker it. Ive just been and looked at it again, the rotor shaft will pull up and then move almost half a turn, but will only fully retract in the position it came from. Also the rotor arm seems to spin normally when the engine is cranked. Do you know if it is spinning ok, because I need to mark its position when the engine is at TDC so it all goes back right don't I? (sorry I haven't done this before) According to the Haynes I have to drain the cooling system too. Nothing is simple! There really should be a warning on the distributor. Many thanks for your help.
ORIGINAL: MattV8i
I love my truck, but as I have found, it is like nothing else out there in some things. I have learned to read up, get on here, and be gentle every time I venture into new territory.
Good Luck with your fix..
I should have taken notice of that warning message before I popped the bonnet!
The landy is immobile at the moment, Distributor is in the Kitchen. I have reattached the weights and springs, and just need to find a new circlip of the right size as i managed to stretch the current one. Will let you know if the landy ever starts again!!
Rover5150
02-03-2008 12:33 PM
amadeusstelfox
07-19-2006 05:01 PM
