1994 V8 Will Not Start After new Rotor Arm Fitted - Please Help
Old Jun 27, 2007 | 07:13 PM
MattV8i's Avatar
3rd Gear
Default 1994 V8 Will Not Start After new Rotor Arm Fitted - Please Help
Hello.
My 1994 Discovery 3.9 V8i Auto started running lumpy on tickover a few weeks ago. It always started and didnt really run too badly. Today I had a look at the dizzy cap and rotor arm and they looked a bit worn, so I bought and fitted new ones, and now the engine turns over but shows no signs of firing.
When I took the rotor arm off, the mechanism below seemed to lift and rotated round but it seemed to only go fully down again in one position - is this normal? Hope I haven't put the timing out!
Secondly can anyone tell me the correct lead order on the dizzy cap just to make sure I have got everything in the correct order. I tried fitting the old parts and it wouldnt start either. Please help!! Many thanks, Matt.
Old Jun 27, 2007 | 08:06 PM
Default RE: 1994 V8 Will Not Start After new Rotor Arm Fitted - Please Help
You will need to get your dist. into a shop and have them rebuild it, Any time you pull the rotor off a old Rover dist. you have to be careful not to pull the lower plate up.
Mike
Old Jun 28, 2007 | 05:59 AM
MattV8i's Avatar
3rd Gear
Oh great, and I thought a 2 min job would make it run better rather than knacker it. Ive just been and looked at it again, the rotor shaft will pull up and then move almost half a turn, but will only fully retract in the position it came from. Also the rotor arm seems to spin normally when the engine is cranked. Do you know if it is spinning ok, because I need to mark its position when the engine is at TDC so it all goes back right don't I? (sorry I haven't done this before) According to the Haynes I have to drain the cooling system too. Nothing is simple! There really should be a warning on the distributor. Many thanks for your help.
Old Jun 28, 2007 | 07:15 AM
I have never had the experience, but have heard alot about it. Won't be much help on telling you what to do, sorry.
Mike
Old Jun 28, 2007 | 11:22 AM
okdiscoguy's Avatar
ORIGINAL: MattV8i
Actually mine had a faded but legible warning on the hood. In 2 inch letters, it said Land Rover right on it....
I love my truck, but as I have found, it is like nothing else out there in some things. I have learned to read up, get on here, and be gentle every time I venture into new territory.
Good Luck with your fix..
Old Jun 28, 2007 | 07:24 PM
MattV8i's Avatar
3rd Gear
I should have taken notice of that warning message before I popped the bonnet!
The landy is immobile at the moment, Distributor is in the Kitchen. I have reattached the weights and springs, and just need to find a new circlip of the right size as i managed to stretch the current one. Will let you know if the landy ever starts again!!
Disco Mike
May 4, 2011 07:08 PM
Rover5150
Feb 3, 2008 12:33 PM
skesner
May 22, 2007 09:29 AM
amadeusstelfox
Jul 19, 2006 05:01 PM
99discoseries2
Oct 4, 2005 05:28 PM
