1995 Discovery Fault Codes?!
Old Oct 9, 2005 | 06:49 PM
kmotors's Avatar
Default 1995 Discovery Fault Codes?!
we have a 1995 Discovery 3.9 V8 in at the moment.. wondering if anyone knew how to read the fault codes from one of these? this is a pre-OBD model.. the vehicle is surging and feels like a loss of power intermittantly.. the Air flow meter has been replaced and everything else checks out ok - adjust the TPS also..
any help appreciated
thanks
Derek
Old Oct 11, 2005 | 09:57 PM
rinmud's Avatar
Default RE: 1995 Discovery Fault Codes?!
clean out all the s--t out of the throttle body first with gum cutter then call me
Old Oct 14, 2005 | 12:05 PM
anonimaus's Avatar
There is a display device with some LED's (OBD I?) under the passenger seat, but I don't think you will be able to get anything useful from it.
Agree with the throttle body and TPS. I would also replace the fuel filter. May also need to clean the stepper motor, as it gets carboned up.
06Range
May 8, 2013 09:01 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
