1995 Just dies while driving it and will not start back up??
Old May 7, 2010 | 09:02 AM
willie2124's Avatar
8th Gear
Default 1995 Just dies while driving it and will not start back up??
I got a 95 Disco that some days will run like a dream and other days she will shut down and die going down the road. When that happens it will not start again. Some days she will start some days she wont. Fuel pump and tank has been changed, gas cap....Has anyone ever had this problem I love this truck and want to keep her but has to be able to go
Old May 7, 2010 | 10:20 AM
okdiscoguy's Avatar
I take it you have checked the cap and rotor, but I do remember that someone else had a similar problem. Turned out to be the air gap setting in the distributor. It would warm up and die.
Also figuring that when it won't start again, you have good fuel pressure?
Old May 7, 2010 | 01:10 PM
willie2124's Avatar
8th Gear
good fuel pressure, you said when it warms up.....could that still be the problem even if it has sit for a few days and still wont start? Thanks for your help to, I am ready to get her back on the road
Old May 7, 2010 | 02:27 PM
Keith95Disco's Avatar
I'll bet my life savings it's the rotor in the distributor! I just had the same problem. Off and on it would or wouldn't start. I spent $500 having some local idiot mechanic replacing parts thinking it was something else. I'm in S. IN...not many Rovers around here.
I contacted another mechanic (2 hours away in TN) that works strictly on Rovers and he told me to buy a rotor and replace the current one. It worked...no issues! The rotor cost $16.
I called OReilly Auto Parts and ordered it. When you order it, give them year, make, model and engine size. If they ask for your VIN give it as well.
Good Luck!
Old May 8, 2010 | 10:21 AM
Rovin4life's Avatar
lucas rotor with a yellow dot works wonders.
had a classic with a no start and it had everything but no start.
Old May 10, 2010 | 07:31 AM
willie2124's Avatar
8th Gear
thanks keith, When i get her back I will try that. She is a a buddy's house and he is looking it over has he has time.
Old May 11, 2010 | 09:01 AM
willie2124's Avatar
8th Gear
I Really do hope this will fix it. If for some reason it does not, does anybody else have any other ideas or experince anything like this before?
Old May 11, 2010 | 09:55 AM
okdiscoguy's Avatar
Just wat I said..... But try the rotor first. I have heard several complaints from not using genuine parts.
Old May 11, 2010 | 12:25 PM
handsome rob's Avatar
I ahd an issue similar when I had my 94', it ended up being the o2 sensors. They were malfunctioning and would send erratic signals to the ecu and would stall the motor, when was the last time you replaced them?
Old May 12, 2010 | 08:51 AM
willie2124's Avatar
8th Gear
The o2 sensors have never been changed....I have a list of things to do to it now air gap setting in the distributor, rotor and the o2 sensors. That least I have places to start. I will go get her next week and do all of this. Thanks for all of your help, I hope to have her back on the road SOON!!
