1997 sd owner
Old Aug 29, 2007 | 05:35 AM
raidernine's Avatar
Default 1997 sd owner
Hello, Maybe you can recommend a brand for O2 sensors that will work better or just as good as the oem that can cost about $250 -$300 per and can I put them in myself as a non mechanic.
Old Aug 29, 2007 | 07:38 AM
Default RE: 1997 sd owner
Contact Atlantic British, they are on sale at $114 each and yes, you can do the work your self.
By the way, what is wrong with yours?
Old Aug 29, 2007 | 08:41 AM
okdiscoguy's Avatar
X2 on what Mike said.
I have been reading your posts. If you are trying to make it start, this won't help. If you are still having the same problem, get back to us. Have a few things to check first.
Old Aug 30, 2007 | 05:45 AM
raidernine's Avatar
Hello guys, My disco run ok now, but after a dino check it said the two front O2 sensors came up on paper. I may need to change all 4 soon, because I do not when the last time the seller did them. Just want to be ready. Does the sensors pop out because I do not see any threads and what tool do I use to remove them if I do the two fronts myself. After I replace them do I need to adjust anything else.
tyrone m.
Old Aug 30, 2007 | 07:52 AM
ORIGINAL: raidernine
tyrone m.
Are you saying you had 2 02 sensor fault codes, if so which fault numbers came up, this is important.
What year is your truck, haow many miles on it?
Old Aug 31, 2007 | 12:10 AM
raidernine's Avatar
Hello mike will have those codes for you friday evening. You suggested me to stay up on my O2 sensors and the dino came up with something. The disc is 1997 SD and it has 100,000. I just bought it with 99.000. With not much info from owner of when the fluid were changed and sensors last changed. Also thanks for the Atlantic British website. Great prices. I may need to know how to change the sensors in the front for now and the back in a month or two. I want to learn to do somethings for myself and leave the rest for the experts. UI can call or email you the info regarding the codes. you # is (303) 862-76.....
tyrone m.
Old Aug 31, 2007 | 07:44 AM
Sure 303-862-7680 or mikeljacobs@comcast.net
one4thg
Jan 27, 2013 02:12 PM
Triumphant
Aug 19, 2011 11:24 AM
raidernine
Aug 29, 2007 08:29 AM
raidernine
Aug 2, 2007 11:06 AM
raidernine
Aug 2, 2007 09:40 AM
