1998 Disco, few questions
I finally finished to repair my Disco yesterday and I got to drive it. I am amazed of how it handles on the road and and comfort. I was also really impressed about the fact that everything works in my Disco, cruise control and AC included!
Changed the oil in my t-case with heavier grade, it damped the grinding noise, but it is still there so i'm looking at a new t-case in the next couple of months.And my CDL shifter works fine. I repaired my power steering leak, seems to work properly. Changed a CV joint, but it is still knocking when I turn...
The problem is, when I turn the wheels, there is a knocking sound as if the truck wasn't made to turn that much. It does it only at low speed, 15 mph or less. It does the same thing when you turn the wheels too much on a Jeep when it is on the 4wd. Any suggestions?
This is the last issue I have to clear out before my Disco is in top shape.
Sounds like maybe your turn stops are out of adjustment, there is a way to increase or decrease your turning radius. If it allows you to turn to tight you could be binding something up.
As for the alarm, it will only turn off when you unlock the drivers door. So if you unlock the cargo door and then open it the alarm will go off. Same with the passenger door.
I assume the light turns off... maybe I opened the door too quickly after I unlocked it so the alarm was still armed...
As for the CV... that was my guess but I hoped for something else...
And I finally got my radio to work... trips were so long without it...
Went off roading a bit today... but I coudn't get the truck dirty, all the mud is frozen in Quebec.
amvauto
08-16-2007 07:50 AM
