1999 D1 - runs beautifully....until it stalls
Old Jun 17, 2009 | 01:37 PM
Luxury's Avatar
6th Gear
I just pulled my dash apart and there is no spider! Does the 99 D1 not have one, or is it somewhere else?
Old Jun 17, 2009 | 04:37 PM
Does your alarm work?
If you lock the door and then open it from the inside does it go off?
I think the only reason they said this is to '98 is because mid '99 is when the DII came out.
But all DI's are the same, so either your alarm has already been removed or you just have not found it.
Old Jun 19, 2009 | 07:56 AM
Luxury's Avatar
6th Gear
The alarm does work, but the spider is definitely not present behind the center console.
I replaced a suspect positive battery cable clamp and cleaned up the the main relay, and now it seems to be running perfectly. It will take a while before I have confidence in it, but I'm certainly enjoying driving it right now.
june82000
Aug 10, 2015 06:53 AM
The HUESTER
Aug 3, 2015 09:18 AM
Bex
May 24, 2013 09:16 PM
MrMoneyBags
Jun 14, 2012 02:44 PM
RTLimo
Aug 15, 2005 12:42 AM
