1999 Discovery II no start
Old Jun 30, 2008 | 08:19 PM
bitter356's Avatar
8th Gear
Default 1999 Discovery II no start
Hello, new to forum, Does anyone now how to diagnose CPS. Just replaced it, no codes at all, still now ignition spark.
Old Jun 30, 2008 | 09:35 PM
Default RE: 1999 Discovery II no start
Are youSURE your not getting spark?
Old Jun 30, 2008 | 10:01 PM
bitter356's Avatar
8th Gear
Yes, no spark.Let me provide history on this specimen. Motor was blown up over heated 3 times. sat in dealer lot for about 1 year. Second owner swaped series 1 engine with series 2 parts including flywheel. I also have all the series 2 engine parts left over. Identified broken CPS and replaced. Here is where I am.
Old Jun 30, 2008 | 10:15 PM
Ok, so you havea GEMS engine in a BOSCH trk.
You might need to swap the ECU, the GEMS engine manegment is very basic and simple, the BOSCH engine manegment is alittle more complicated and the DI engine isint set up for that. I know that you can drop a DII engine into a DI but am not sure about the other way around.
The engine doesnt care what it is hooked up to but the ECU does, if everything isint connected then the ECU will think that there is a problem and it might not run.
Old Jun 30, 2008 | 10:20 PM
bitter356's Avatar
8th Gear
Thanks for the help. Let me expand a little. The heads and intake, timing cover, injectors have been swapped. Everything to operate on OE ststem.
Old Jun 30, 2008 | 10:33 PM
OK, so you didnt swap the enigne and go, you changed the block and re-used the good parts from the bad engine.
So everything that is supposed to be connected is connected.
No spark.
Replaced crank sensor, how about the cam sensor? Oh, did you use the right crank sensor? Will a DI crank sensor plug into a DII harness? If it will plug in will it send the right signal?
I dont know the answers to these questions but maybe somebody else will.
Now it is WAY past my bedtime so I am going to have to leave you until after work tommorrow.
Good luck with your trk.
Old Jun 30, 2008 | 10:47 PM
bitter356's Avatar
8th Gear
The engine was complete when I purchased.All the connectors are in the correct location. Ther is no visable modifications of harness. Have all the paper work to support the over heating problem. The original block has a crack in a cylinder. It appears the short block from the series 1 was all that was used.
Old Jul 1, 2008 | 09:23 PM
I dont know man, I am at a loss.
58ford
Jul 13, 2011 06:07 AM
vin1124
May 12, 2011 10:57 PM
Schloesser
Apr 17, 2011 02:12 PM
armyeng
Mar 8, 2011 05:58 PM
city2city
Jun 9, 2010 04:13 PM
