1999 Land Rover Discovery II Cranks with no start
Old Dec 29, 2017 | 01:07 PM
sampsonm105's Avatar
3rd Gear
Exclamation 1999 Land Rover Discovery II Cranks with no start
I have a 1999 Discovery II that will crank, but no start, no fire, no spark, no injector pulse. Tachometer (RPM gauge) does not move while cranking, however engine diagnostics says there is a reading. Battery is good, alternator is good.
Changed the crankshaft sensor with still no change. Waiting on camshaft sensor to arrive, but unsure if this will even fix the issue.
Will a faulty camshaft sensor or O-Ring around the sensor cause this type of problem? Does anyone have any suggestions on what the problem might be. My father and I are stumped if the camshaft sensor doesn't fix this.
Old Dec 29, 2017 | 05:45 PM
mollusc's Avatar
Did you check the inertia switch on the firewall?
Old Dec 29, 2017 | 05:48 PM
3rd Gear
Yes. The fuel pump does work.
Old Dec 29, 2017 | 06:10 PM
mln01's Avatar
What you report are the classic crankshaft position sensor symptoms. Are you certain you installed it correctly? I don't recall the camshaft position sensor causing the symptoms your truck is exhibiting.
Old Dec 29, 2017 | 06:20 PM
3rd Gear
I am pretty certain the crankshaft sensor was installed correctly. However, we plan on taking a look at it to make sure it is when we get the camshaft sensor in. I read somewhere that sometimes both cam and crankshaft sensor should be changed together. I also read somewhere that it might be the timing?
I did see something somewhere about the vehicle “thinking it has been stolen”, but I am not sure how to test that or even go about fixing it.
Old Dec 29, 2017 | 07:43 PM
zuke's Avatar
If all else fails I would look at replacing the ecu. I bought one out of a junkyard cuz nobody could fix it. It acted just like what you described. I got a used ecu, bcu, and gauge cluster for 100 bucks and she fired right up.
whitehat
Oct 29, 2012 02:13 PM
jrkstore43
Sep 28, 2012 04:16 PM
texmanmoore
Dec 5, 2010 12:45 PM
jennina1
Aug 15, 2009 09:45 AM
