2” lift with rear air springs
Hello,
I add to my „Disco” some extra heavy equipment (metal bumper + winch) located on the front axle. The balance is about 100 kG, so I think about suspension change. I would like to convert original front springs for medium-duty springs 2”lift. In conjunction with appropriate shock absorber, of course.
The rear suspension is classical air. It works fine so I do not like to replace it. I know that I should use special spacer blocks to elevate rear air bags (to hold the level car body), and also change the shock absorbers.
My question is: should I do anything with ride height sensors ? Are they able to work with 2” lift ? Should I use any dedicated spacer for them ?. May be some kits on the market prepared for such a conversion.
Thanks for ideas and help,
Best regards,
Piotr Szulewski
Best regards,
Piotr Szulewski
97GreenMeanie
05-21-2015 08:24 PM
rchrd0413
04-22-2014 02:18 PM
Bellows Fellow
09-15-2010 02:29 PM
rich
03-07-2010 02:52 PM
khtemple
09-14-2006 06:00 AM
