2” lift with rear air springs
Old Sep 24, 2012 | 05:22 AM
Maxer's Avatar
Default 2” lift with rear air springs
Hello,
I add to my „Disco” some extra heavy equipment (metal bumper + winch) located on the front axle. The balance is about 100 kG, so I think about suspension change. I would like to convert original front springs for medium-duty springs 2”lift. In conjunction with appropriate shock absorber, of course.
The rear suspension is classical air. It works fine so I do not like to replace it. I know that I should use special spacer blocks to elevate rear air bags (to hold the level car body), and also change the shock absorbers.
My question is: should I do anything with ride height sensors ? Are they able to work with 2” lift ? Should I use any dedicated spacer for them ?. May be some kits on the market prepared for such a conversion.
Thanks for ideas and help,
Best regards,
Piotr Szulewski
Old Sep 24, 2012 | 07:16 AM
drowssap's Avatar
you can buy air spring spacer try Land Rover Discovery Series II 1999.5-2004 Suspension Lift Kits
Old Sep 24, 2012 | 09:17 AM
If you want 2 more inches to the rear, RTE and Lucky 8 have a 2" spacers that comes with height adjuster for the switches, I used them for year for a good 3" lift with no problems.
97GreenMeanie
May 21, 2015 08:24 PM
rchrd0413
Apr 22, 2014 02:18 PM
Bellows Fellow
Sep 15, 2010 02:29 PM
rich
Mar 7, 2010 02:52 PM
khtemple
Sep 14, 2006 06:00 AM
