Is a 2.5" pipe wide enough for a 4.0 to breathe through?
Old Jul 10, 2010 | 05:23 PM
kingsly's Avatar
Default Is a 2.5" pipe wide enough for a 4.0 to breathe through?
Building a raised intake and found this awesome flexi pipe for some of the more complex bends that is approx 2.5" in diameter...
Help?
Old Jul 10, 2010 | 08:13 PM
Rovin4life's Avatar
measure the intake hose
Old Jul 10, 2010 | 09:36 PM
rtonder's Avatar
It should be larger, perhaps 25% larger than what is on the intake ducting since you're increasing the distance that the air must flow through the system. Note to that the inside of most of the intake duct are smooth plastic, and when you use a flexible connector it creates an even greater resistance to flow.
All this might not be an issue if your running at relatively low RPMs. Good luck on your project - it sounds like fun.
Old Jul 10, 2010 | 11:42 PM
Spencerfitch's Avatar
dryer hose ftw lool
jycsalas
May 23, 2019 03:02 PM
j.broadwater
Oct 18, 2016 05:10 AM
coors
Oct 1, 2012 02:33 PM
yukonridin23
Sep 22, 2009 01:18 AM
jlester@mt.gov
Mar 26, 2008 09:30 PM
