2 more things checked off the 60k
Old Oct 16, 2010 | 10:14 PM
sloppyjoe's Avatar
Default 2 more things checked off the 60k
did my power steering fluid and O2 sensors today.
for anyone looking to do the sensors soon they are a piece of cake. make sure exhaust is warm (not hot) and with a 22mm open end wrench they can be taken out easily with not much effort. unclipping the looms is the hardest part. passenger side is really tucked up and away but not impossible to get to.
truck runs way better and smoother.
did the PS fluid and replaced it with sythetic atf as i do on all my vehicles.
carry on men.
Old Oct 17, 2010 | 07:04 AM
Well you screwed up on this one, Joe.
You may use ATF in your other vehicles but not in a D2.
I would suggest you go buy 4 quarts of Power Steering fluid and flush it out today before our already fragile p/s pump starts to feel the effects of the wrong fluid.
Old Oct 17, 2010 | 08:00 AM
hilltoppersx's Avatar
i added a bottle of lucas synthetic power steering treatment (not the stop leak) to mine. i like the way the pump runs with that in it, or royal purple makes a PS fluid.
Old Oct 17, 2010 | 08:18 AM
If it weren't so expensive, I would probably do a full flush and go straight synthetic, and may when I replace my pump, somewhere down the road.
Old Oct 17, 2010 | 11:18 AM
sloppyjoe's Avatar
what is so different between the two fluids that it effects our pumps more then other pumps? And what is it that makes our pumps so fragile?
Old Oct 17, 2010 | 01:49 PM
Hey what are you driving, this isn't the only thing that is different between Rovers and the rest of the world, but trust me it will bite you.
Old Oct 17, 2010 | 05:17 PM
boxerboy2's Avatar
Ok stupid ? --Do you just change out the fliud in the tank or do you flush the PS system? If its a flush -- how do you do it?
thanks!
Old Oct 17, 2010 | 06:38 PM
thanks!
The only stupid question is the one not asked.
Do a flush, its messy, this is how I do it...
Remove the return line power steering hose from the reservoir and stick it into a empty washer solvent bottle.
Have a friend start the engine while you pour fresh fluid into the reservoir.
Make sure your washer jug does not overflow.
Once fresh fluid comes out of the hose turn off the engine.
Put the hose back.
Refill with fresh fluid.
Done.
Doing this will replace 100% of the old fluid with new.
Old Oct 17, 2010 | 07:40 PM
boxerboy2's Avatar
thanks! how are the bumpers coming out?
Disco Mike
Dec 5, 2018 03:56 PM
tornado_735
Mar 8, 2009 07:49 PM
jrkstore43
Mar 2, 2009 08:29 AM
Kinversand
Jun 30, 2008 08:31 AM
ryant06
Mar 21, 2008 05:34 PM
