2 unused connectors in wiper blade channel
Old Mar 10, 2011 | 09:10 PM
grandkodiak's Avatar
Default 2 unused connectors in wiper blade channel
2 pin connectors (purple and black wires?) on oposite sides of the car both mounted in the channel below the wiper blades, far corners of the car facing rear center at an angle.
what are these for?
other unknown is on the firewall, passenger side, about level with the exh manifold, has a dust cover and is a large circular white connector of some sort.
Old Mar 10, 2011 | 09:13 PM
Snafu / Disco Fries's Avatar
Repost! J/K... I'm not the STFA type. They are for the heated windshield.
Old Mar 10, 2011 | 09:56 PM
lordmorpheus's Avatar
The second part sounds like you're describing the inertia switch (cuts off the fuel pump in the event of sudden impact, and can be reset with the rubber button on top).
Old Mar 11, 2011 | 07:20 AM
jeffh's Avatar
Yep Heated windshields.....Not certain about the others you are talking about. How about a picture or two... for clarity.
Old Mar 11, 2011 | 12:04 PM
JerrodSteph's Avatar
Yeah I have those plugs too on mine, but have the OTHER end attached as well wires are cut so somebody repl the windshield with non heated, I think its because the heated screen is crazy expensive.
Old Mar 11, 2011 | 01:31 PM
RAYMAN975's Avatar
i heard around $1200, but im not sure.
bcolins
Feb 2, 2014 09:40 PM
bigugly82
Apr 4, 2007 06:30 PM
huckleberry
Nov 8, 2006 11:06 AM
discoverylady
Oct 28, 2006 07:42 PM
studlee
Aug 8, 2006 10:29 PM
