2000 d2 head gasket job
Old Jun 21, 2010 | 09:41 AM
kemil77's Avatar
Default 2000 d2 head gasket job
Can some1 list all the parts required 2 complete a head job includn gaskets n tha size head bolts. N wat all tools needed. Tryn 2 get everythng lined up n organized
Old Jun 21, 2010 | 10:20 AM
yloDiscoII's Avatar
http://www.roverparts.com/Parts/STC4082BK.cfm
There's a start...You'll need new head bolts too.
You can also refer to this thread to get an idea of what you're getting yourself in to https://landroverforums.com/forum/sh...ad.php?t=31663
Old Jun 21, 2010 | 12:45 PM
kemil77's Avatar
There's 2 differ size head bolts. Do u use both sizes wen remounting the heads
Old Jun 21, 2010 | 02:51 PM
Bundu's Avatar
Banned
You need this
http://www.roverparts.com/Parts/9224.cfm
Old Jun 21, 2010 | 04:51 PM
Beside those parts, you'll want a new t/stat, upper radiator hose with up-dated bleed screw and all fluids and a good shop manual.
Based on your questions, have you ever done this before or know how?
Old Jun 21, 2010 | 08:23 PM
Willie00d2's Avatar
I would also change the oil seperator, located in the valve cover breather tube. Mine was totally clogged. Also make sure all the rocker oil holes are clear.
Willie
Old Jun 21, 2010 | 09:00 PM
kemil77's Avatar
I changed heads on a 78 cutlass but not on a newer car. But ima sure try
Old Jun 22, 2010 | 10:53 AM
yloDiscoII's Avatar
If you've changed the heads on an Olds, you might find this interesting....I hate wikipedia, but here you go...
http://en.wikipedia.org/wiki/Rover_V8_engine
a-rod
Sep 21, 2013 09:33 PM
FlyingZebra34
Apr 25, 2013 08:04 AM
01 Discovery SD
Mar 1, 2009 12:11 AM
Darover
Oct 17, 2007 02:50 PM
fsufan8
Aug 5, 2005 03:48 PM
