2000 D2 V8. Crank, but no start P1842 and P1843 codes
Old Oct 2, 2025 | 11:35 AM
  #21
Kurgan's Avatar
I am having this exact same problem with my 99/00 D2 V8. Battery died replaced the battery. Crank, no spark or fuel pump and i have most of those codes.
Wife wants to burn the car...
Old Oct 2, 2025 | 12:02 PM
  #22
bripark3's Avatar
I swapped to the other BCU and it starts runs and drives. Now to deal with the 3 amigos and the stuck on brake light and the exhaust bolts that I snapped while changing the CKP sensor. Thank you to everyone who offered suggestions and help!
Old Oct 2, 2025 | 12:05 PM
  #23
bripark3's Avatar
@Kurgan swap the crank position sensor first if you haven't already, but what finally worked for me was swapping the ECU and possibly the BCU as well. I got the original and new BCUs mixed up when swapping everything out, one worked and the other didn't. I'm fairly certain the new one worked because I no longer can use my key fob. Either way if you have to swap the ECU and BCU get a matching set to be safe
Old Oct 2, 2025 | 06:01 PM
  #24
Kurgan's Avatar
I have a matching set ECU & BCU from the same donor vehicle. Does that cure the problem?
Old Oct 2, 2025 | 06:38 PM
  #25
bripark3's Avatar
It fixed mine can't say for sure it'll fix your issue, but it's easy to swap and test out since you've already got them
Old Oct 6, 2025 | 01:26 PM
  #26
H20nSnow's Avatar
I followed Brandon318's recent post about a similar issue and decided to pull my fuse box and open it up. for anyone familiar with circuit boards does the above look like damage or something that could cause an issue?
Originally Posted by JohnZo
To me the round dome solder looks like a repair. From what I have seen, the tent-like solders (pole in the middle with solder drooping outward) are what can be a problem. On the tents, the solder is thin enough that high current heats the solder, eventually melting it away in a dark black circle around the pole. A magnifying glass is useful to find the faulty solder joints, since they can be hard to see with eyeballs alone. The repairs I have done re-melt the solder and add more, that can create a shiny dome shape. More solder makes less resistance that gets less heat when current flows.
The spot you are questioning looks like a repair performed by a non-professional. The rosin that wasn't cleaned up and the excess solder is a usual indicator for non-pro work. There is nothing about that joint that looks bad in that pic however.
What @JohnZo says about it being hard to identify a bad solder joint by eye is true. If one has any reason to suspect a bad solder joint on a board, it is a decent idea to retouch all of the joints. What John says about adding solder and ending up with a dome is something I'll respectfully call a bad idea though. Excess solder runs through the hole to the other side and you end up with excess on both sides. Depending on what the device is that's attached there, you could be causing an invisible short on the topside of the board, plus, it's just too much solder. Goldilocks joints - not too much solder, not too little solder, just the right amount of solder.
Titansview
Nov 20, 2021 11:53 AM
john47uk
Oct 3, 2014 01:32 PM
Alex J
Nov 29, 2010 11:37 AM
nfakbc
Apr 8, 2010 03:51 PM
possibly owner
Sep 20, 2009 02:02 AM
