2000 disco 2 no spark need help
Old Aug 5, 2011 | 07:40 PM
funjohnny69's Avatar
Default 2000 disco 2 no spark need help
Hello i am new to the forums. I have a 2000 disco 2 i took it to store ran fine came out wouldnt start then after about 15 mins it started went home parked it it wont start again. I took off spark plug wires and i am not getting any spark from none of the wires. could it be ignition coils or could it be something else? I checked all my fuses and they are good any help you be great. Thanks
Old Aug 5, 2011 | 08:02 PM
Bad crank position sensor.
Check the tech section for the write up on how to replace it.
The crank sensor controls spark.
Old Aug 5, 2011 | 08:06 PM
lordmorpheus's Avatar
Crank sensor as Spike said.
Old Aug 5, 2011 | 08:13 PM
Thanks alot guys i will give that a try...
Old Aug 5, 2011 | 08:19 PM
0304Disco's Avatar
It's the season for these puppies to fail. High heat+high underhood temp. Replace the CPS and you'll be good.
Old Aug 5, 2011 | 09:21 PM
Kalel's Avatar
I should vent my hood.
Old Aug 5, 2011 | 09:39 PM
Nah, that would disrupt the esthetics, and if you popped the hood every time you stopped, you would give LR a bad rep! Just get some clothes drier vent hose routed to the CPS, with the other end piped into your A/C duct-work!
Old Aug 5, 2011 | 10:19 PM
Kalel's Avatar
I was going '69 GTO style.
Old Aug 6, 2011 | 07:29 AM
0304Disco's Avatar
I could see it now and like the creativity!!
DISCO JAK
Feb 3, 2014 07:02 PM
johndavidrichards
Jun 17, 2011 09:26 PM
Classklown90
May 2, 2010 09:34 PM
possibly owner
Sep 7, 2009 08:33 PM
pilsner
Oct 5, 2008 03:36 PM
