2000 Disco 2 - Tires and Lift Question
Old Nov 26, 2006 | 11:31 PM
bdharvey74's Avatar
5th Gear
Default 2000 Disco 2 - Tires and Lift Question
I am looking to upgrade my disco 2 a bit and need some advice. I would like a little bit bigger tire and possibly lift the truck no more than 2". From what I have read it looks like an Emu body lift and possibly 255/75/16's? Just want something more aggressive looking without having to do major modifications. Thoughts?
Old Nov 27, 2006 | 12:17 PM
Default RE: 2000 Disco 2 - Tires and Lift Question
A lift is easy and a very common thing to do on D2's. One thing to consider of course is gas mileage, if you want a good looking truck, you can do the lift and install 265/75/16's but you can loose up to 1 1/2 MPG overall.
OME suspensions are the way to go, check out the write up on this web site https://www.expeditionexchange.com/ome/indexsprings.htm
Do you paln on a HD front bumper and or winch. if so this will be a consideration when picking the coils, I install the 751 coil with OME HD shocks in the front of my D2 and run the 265's.
Mike
grandkodiak
Mar 4, 2011 08:00 PM
pvenuti
Oct 13, 2010 03:48 PM
TD4141
Dec 9, 2008 12:06 PM
uziduzit
Aug 17, 2007 09:08 PM
Mr. Krisztian
Aug 16, 2007 11:36 PM
