2000 Disco Fuel Pump
Hey, I'm new here and I thought you guys would be able to help me. This is my first rover that I've owned and it's got a bad fuel pump the guy I bought it from told me, so I got a used pump from a 99 disco (mine is a 2000), will the pump from the 99 work in the 2000? Cheers!
I would stay away from a pump with more then 100,000 miles on it cause they do wear out and will not supply the fuel pressure required.
What exactly is wrong with your current pump and be specific as to what has been checked so far?
There are rebuilt kits for the D2 pump on ebay, I'm not sure if they are legit though. If your plastic housing for the pump isn't bad/cracked look into that, if you don't know if its cracked go under the truck while its running and smell for fuel. I had one that was cracked so I had to pony up the 400$ for one :/
Travelor
Sep 24, 2015 06:11 PM
Sine Mora
16
Sep 7, 2014 05:47 PM
caneraiser
Oct 31, 2012 06:15 PM
JumPeR04
Apr 7, 2011 09:52 PM
marlymarl
Feb 17, 2010 08:07 PM
