2000 Disco II
Old Sep 27, 2010 | 03:27 PM
swissmachine's Avatar
3rd Gear
Default 2000 Disco II
My wife called Friday and told me that the disco was leaking antifreeze into the passenger compartment. I was working on the boat all weekend so I did not get a chance to take a look at it. My first instinct was a heater core, after looking through the posts I did not see any threads on here in regards to heater core. Could I be barking up the wrong tree, I just wonder @ 96K if I have a headgasket problem? Does not seem to be smoking but I will take a better look this evening?
Also if it is a heater core how tough of a job would this be, I found the part for about $100.
Thanks in advance
Old Sep 27, 2010 | 03:58 PM
SDinDS's Avatar
Double check it to make sure it's coolant. You're in Knoxville? I'm just east of you. With all the rain we've had, there's a possibility the sunroof drain is plugged and running down the pillar to your floor. (common problem) At 96kmi, I doubt it would be the heater core, but I could be wrong. Hopefully it's not. Download the Rave manual and you'll see the heater core is a project! (Unless someone knows a shortcut)
Eric
Old Sep 27, 2010 | 04:01 PM
NiteTrain's Avatar
a plugged A/C drain line will also cause water to be inside cabin..so yeah verify it is coolant
Old Sep 27, 2010 | 04:06 PM
Is the carport wet with water or a sweet/oily smelling fluid.
Head gaskets won't cause this to happen.
duke051184
Jan 14, 2013 02:23 PM
Disco2Fever
48
Mar 12, 2012 12:39 PM
Airwolf1
Nov 6, 2006 04:27 PM
paul_b
Jul 2, 2006 10:53 AM
