Just got back from the dealer....
Old Sep 27, 2010 | 09:45 AM
SDinDS's Avatar
Default Just got back from the dealer....
Went there to get this issue with the "faint alarm sound" coming from the ABS unit. Service dept said they were unaware of any TSB on it. I asked them to re-program the ABS module anyway and I'll see what happens. They only charged me $50 which I thought was very reasonable. Also ordered up a few parts which I haven't found elsewhere. This is the first highway trip I've made with my D2 since doing the head gaskets and working out all the other gremlins. 70 mile roundtrip and it ran great!! My only complaint is the tires. They're Uniroyal Liberator All Terrain (255/70/16).... not exactly a "quiet tire"
Eric
Old Sep 27, 2010 | 10:31 AM
Did your noise go away?
How old is your brake fluid, or maybe I should ask, when was the last time you did a 2 quart bleed to prevent module issues?
Old Sep 27, 2010 | 10:38 AM
SDinDS's Avatar
The noise is gone.... for now. It doesn't always happen, just about 70% of the time.
I've only had it for 2 months so I don't know how old the brake fluid is. PO said front calipers and brakes were replaced but don't know when.
Eric
Old Sep 27, 2010 | 11:26 AM
With your mileage, you should foolow my service list and get that truck current before it starts costing you big dollars.
Old Sep 27, 2010 | 01:41 PM
SDinDS's Avatar
Thanks Mike! During the engine rebuild, I was able to get a lot done on that list. Brake fluid and differentials are next. I haven't driven it much at all because I have the factory drive shaft. (The PO replaced it last year with one from the dealer) I don't know how long the OEM one will last and I'm not going to find out. So this weekend's project (weather permitting) is drive shaft, brake fluid flush, then differentials.
Eric
Old Sep 27, 2010 | 04:17 PM
SDinDS's Avatar
Mike, also have a question on the differential and t-case fluid. On your sticky you mention "7 Qts. of 80/90W synthetic gear oil, 85W/140 for HD use" I hardly do any off-road but plan on towing a trailer on my many trips from Home Depot. Trailer weight might be around 2,500lbs. Will the 80/90W be sufficient or should I use the 85/140?
Eric
Disco3JR
Jun 22, 2015 09:29 PM
billyd1967
May 20, 2011 10:09 AM
SpyderMan1964
Mar 1, 2010 05:31 PM
kallgrer
Jan 14, 2010 08:54 AM
suplada
Dec 8, 2008 06:03 PM
