2000 Disco II having starting/idling problems
Thanks James, I feel like I had read that before. The other codes seem to stem from a SAI problem of some sort. I poked around for a little bit earlier checking hose connections and what not, but had to come back in and check the RAVE manual. Need to familiarize myself with what it is that i'm looking at (potentially further breaking) before I go taking it apart.
Any good staring points for SAI fixes, and links/stickys/direction for starting the tres amigos undertaking would be appreciated.
Start here for the three amigos
https://landroverforums.com/forum/di...s-fault-26847/
Excellent write up with super easy directions/pictures to follow you through the whole thing.
Is your SAI making any funky noises? Can you hear it upon a cold start up?
Your SAI pump should sound like a hair dryer upon a cold start up. Pop the hood and have someone crank it for you and listen to the SAI. If there is no sound, then you probably have a bad SAI altogether. If you hear the hair dryer blowing sound, the next thing to do would probably be to clean the filter inside the SAI.
Well not hearing a particular hairdryer sound, I did however notice these black and yellow wires that are disconnected on the passenger side. There is one on the driver side that attachs through the hood into the dash(?) any ideas what this may be for?
Aslo where is the SAI filter located? If I can find it I can clean it. I apologize for all the questions. I'm a very novice mechanic but an avid DIY'er, I've used the rave manual to identify all the parts of the SAI system, and found another diagram as well.
Again thanks for the help
please help me
hi everybody i have a 2000 landrover discovery 2 im having a loud whistling noise coming out of my idle contol air regulator the only time it dont whitsle is when i push on the gas. it is loud as hell and i all ready bought a used idle contol vavle and a brand new one. i called up land rover and they said that part never goes bad but when i put my ear up to it i can hear it plan as day. what is going on with my truck!!!!!!! anyone????
megagame
10-24-2014 06:53 AM
