2000 DISCO II Ticking noise
Old Nov 23, 2006 | 02:02 PM
marlymarl's Avatar
Default 2000 DISCO II Ticking noise
I have a 2000 Discovery II with only 59,000 miles on it. Regular oil changes from the dealer only as well as scheduled maintenance.
I hear a ticking noise coming from the engine only when I have driven the car for a while and only when the car is in park. Can someone please help me figure out what the problem is????
Old Nov 24, 2006 | 11:19 AM
Default RE: 2000 DISCO II Ticking noise
Are you saying you have only had your oil changed every 7500 miles, if so that is most likely the problem.
Rovers run rich, foul out their oil and build alot of engine sludge which can cause the lifters to plug or the rocker ares to wear out.
Mike
Old Nov 24, 2006 | 12:19 PM
marlymarl's Avatar
I have the oil changed in between trips to the dealer. Do you think the engine is Toast?
Old Nov 24, 2006 | 02:52 PM
No, not at all, most likely time for a good engine flush, clean out some sludg and carbon build up.
Can you do a oil change at home if so I'll walk you thru a few basic steps to make your engine happier.
Mike
Old May 7, 2011 | 10:00 PM
tonewerks's Avatar
I would like to de sludge my motor what do you recamend ? thanks Mike
Old May 8, 2011 | 06:41 AM
Either drain the oil, replace it with 6 quarts of ATF, using the old filter, and let it idle with the hood closed and the a/c off, for 30 minutes or quit having the dealer change your oil and start using 1 quart of of Gunk engine flush prior to your oil change and then do the change yourself using 6 quarts of Rotella 15W40 synthetic and a Mobil1-301 oil filter. You should be changing your oil every 3000 to 5000 when using a synthetic and stay away from the dealer.
Old May 23, 2011 | 12:21 AM
tshah209's Avatar
you sure rotella make a 15w/40 "synthetic?"
Old May 23, 2011 | 06:54 PM
photocrimes's Avatar
Oil changes on these things are so ridiculously easy there is no reason to use the dealer, or a quick lube. You don't need jacks, everything is right there, and the oil filter is in a spot where you can get both hands on it and lots of leverage. I've never even needed a filter wrench. I just switched from Rotella T6 to Mobil 1 high mileage. Used to run a factory filter but have a 301 on it now because it came free with the oil. Has been running great and so far the leaks are holding off ;-)
Humdinger
Oct 18, 2016 05:05 PM
john65b
Oct 10, 2013 05:00 PM
30more
May 28, 2012 05:01 PM
DeepBlueWater
Sep 27, 2007 07:39 PM
SUMOSINO
Nov 22, 2006 11:40 AM
