2000 Disco - Rear Window Will Not Roll Up?
RE: 2000 Disco - Rear Window Will Not Roll Up?
one of the most common problems with the disco. usually the problem is the regulator in the window. a small plastic wheel breaks. that wheel keeps the window in it's track. Look in the owners manual for fuse locations, and test to see if that is the problem. It could just be stuck. You didn't mention whether you could hear the motor. There is a list of parts suppliers in the forum. you can do the search there. also in the tech area. Hope it helps, gotta love a rover. duboff
twoxred
10-04-2021 07:07 AM
