2000 Disco - Rear Window Will Not Roll Up?
Old Aug 12, 2005 | 01:11 PM
dailyuser's Avatar
5th Gear
Default 2000 Disco - Rear Window Will Not Roll Up?
is there a fuse or something to check?
Old Aug 12, 2005 | 02:50 PM
duboff's Avatar
Default RE: 2000 Disco - Rear Window Will Not Roll Up?
one of the most common problems with the disco. usually the problem is the regulator in the window. a small plastic wheel breaks. that wheel keeps the window in it's track. Look in the owners manual for fuse locations, and test to see if that is the problem. It could just be stuck. You didn't mention whether you could hear the motor. There is a list of parts suppliers in the forum. you can do the search there. also in the tech area. Hope it helps, gotta love a rover. duboff
twoxred
Oct 4, 2021 07:07 AM
evansjoem
Sep 30, 2014 07:14 PM
SC Rovergirl
May 15, 2010 07:06 AM
01DiscoII
Apr 9, 2008 03:57 PM
01DiscoII
Apr 9, 2008 01:02 PM
