2000 discoII subwoofer wiring help?
Not sure of the wiring for a D2, or if the amp can be bridged, but here is a link for the wiring on a D1 LSE. It has the 6" dual voice coils as well...
bottom of the page...
http://home.twcny.rr.com/eeibooks/rover/discosubs.htm
Hi, a schematic probably wont help much as it does not determine + or -, but by usingthis below you can pretty much work out what is what, by looking at the colour codes to
![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
Low range tail door speakers
The power amplifier is connected to the low range tail door speaker 1 on a KB
wire. From the low range tail door speaker 1 the connection returns on a RB
wire to the power amplifier.
The power amplifier is connected to the low range tail door speaker 2 on a NB
wire. From the low range tail door speaker 2 the connection returns on a WB
Code Colours
B Black
Black with a tracer is also usually an earth wire, but
with the earth switched by an ECU.
G Green
K Pink
LG Light Green
N Brown
O Orange
P Purple
R Red
S Slate (Grey)
U Blue
W White
Y Yellow
As already stated, if you "bridge" the AMP outputs, you will half the impedance, and "May" blow the amp if you turn it up to much as it will try to deliver to much and cook itself. The rear subs are 30 watts each and 4 ohms.
it may be a better idea if you really want a bigger sub, to buy and additional AMP that will accept "high level" inputs, so use one of the sub outs from the factory AMP and use the newAMP only to drive the 10"sub.
dbs600
04-16-2007 01:20 PM
