2000 discoII subwoofer wiring help?
Old Jun 27, 2008 | 03:24 PM
harp's Avatar
3rd Gear
Default 2000 discoII subwoofer wiring help?
I need a wiring schematic as I replaced the two 6 1/2 inch rear woofers with a 10 inch subwoofer in the back. I need to bridge the 4 wires to the +/- of the new speaker,and I can't figure out the combination to fix the phasing issue.
Thanks!
Old Jun 27, 2008 | 07:34 PM
okdiscoguy's Avatar
Default RE: 2000 discoII subwoofer wiring help?
Not sure of the wiring for a D2, or if the amp can be bridged, but here is a link for the wiring on a D1 LSE. It has the 6" dual voice coils as well...
bottom of the page...
http://home.twcny.rr.com/eeibooks/rover/discosubs.htm
Old Jun 27, 2008 | 07:52 PM
Urban Panzer's Avatar
Hi, a schematic probably wont help much as it does not determine + or -, but by usingthis below you can pretty much work out what is what, by looking at the colour codes to
Low range tail door speakers
The power amplifier is connected to the low range tail door speaker 1 on a KB
wire. From the low range tail door speaker 1 the connection returns on a RB
wire to the power amplifier.
The power amplifier is connected to the low range tail door speaker 2 on a NB
wire. From the low range tail door speaker 2 the connection returns on a WB
Code Colours
B
Black
Black with a tracer is also usually an earth wire, but
with the earth switched by an ECU.
G
Green
K
Pink
LG
Light Green
N
Brown
O
Orange
P
Purple
R
Red
S
Slate (Grey)
U
Blue
W
White
Y
Yellow
As already stated, if you "bridge" the AMP outputs, you will half the impedance, and "May" blow the amp if you turn it up to much as it will try to deliver to much and cook itself. The rear subs are 30 watts each and 4 ohms.
it may be a better idea if you really want a bigger sub, to buy and additional AMP that will accept "high level" inputs, so use one of the sub outs from the factory AMP and use the newAMP only to drive the 10"sub.
aguison
Oct 9, 2012 07:57 AM
harp
Mar 14, 2012 02:37 PM
kjmass1
Aug 18, 2010 08:19 PM
Core_Shot
Feb 1, 2008 12:31 AM
dbs600
Apr 16, 2007 01:20 PM
