2000 4.6 HSE Subwoofer Rumble When Rainning / Snowing
Old Jul 9, 2005 | 12:04 AM
dbs600's Avatar
Default 2000 4.6 HSE Subwoofer Rumble When Rainning / Snowing
Hello:
I am the owner of a 2000 4.6 HSE. I have an extended warranty on the vehicle, however I have an intermittent problem that does not seem to go away - and whenever I bring the vehicle in for servicing, they are never able to reproduce the problem.
Problem being - When it rains / snows and I turn on my radio there is this loud rumble from the subwoofer that seems to get louder / increase in intensity the longer the radio is on. When turning on / off the radio, changing presets, or moving from am - fm - wb - or to - cd there is this loud (single) thump sound.
What should I do? Do you have any recommendations as to diagnosing and fixing the problem myself? Have you come across this problem before?
Much thanks!
Old Jul 16, 2005 | 09:49 PM
Bait's Avatar
Default RE: 2000 4.6 HSE Sub woofer Rumble When Raining / Snowing
Your X-warranty most likely won't cover a radio issue anyway. Are you sure about the rain / snow connection ? Are you from the States ? It could be a bad ground. Most likely a bad amplifier. Does it happen with a CD playing ?
Hmm.... These kinds of problems usually are not intermittent.
Old Aug 5, 2005 | 04:01 PM
duboff's Avatar
Default RE: 2000 4.6 HSE Subwoofer Rumble When Rainning / Snowing
i hadthe same type of problem. bait has it pretty much covered. Hope it helps. gotta love a rover. duboff
Old Jun 15, 2006 | 01:52 AM
IconDrummer's Avatar
5th Gear
I am having this same problem. There is nothing comming out of the sub and when I turn on the radio or change the station it thumps. Also my drivers side rear interior light flashes with the bass. Im thinking its the ground but usually a bad ground will give a whinning sound with the engine... not a thump. So im a little confused. Any ideas?
Old Apr 16, 2007 | 01:20 PM
Turp's Avatar
4th Gear
Go to rangerover.net That is a corroded ground in the door panel. Easy fix!! Very common.
jallert
Dec 13, 2009 11:34 PM
range03
Apr 14, 2009 06:33 AM
mattlapper
Aug 8, 2007 09:40 AM
maverick544
Aug 3, 2007 05:54 PM
disco12
Off Topic
Feb 16, 2006 04:36 AM
