2001 disco brake disc broken
Old Apr 12, 2008 | 03:49 PM
dapo's Avatar
Default 2001 disco brake disc broken
Hi,
Can someone advise pls. My driver side brake disc got broken today (2001 disco V8), my technician said the last guy that worked on it didn't tighten the bolts well. My problem is that when I tried to search for the disc on ebay, i saw some vented and some are not, what is the difference?
where in the UK is best and cheap to get the spare parts from?
A quick response will be appreciated.
Old Apr 12, 2008 | 06:08 PM
Default RE: 2001 disco brake disc broken
Basically vented disc's have holes to remove heat and solid disc's to not.
You will need to replace both fronts at the same time, when it comes to brakes you must do an entire axle, not just one side.
I do not know which the DII has, nor do I know where is a good place to buy parts in the UK as I am in the States.
You can use either.
euronavdiscs
Feb 6, 2016 03:41 PM
victorioustilldeath
Apr 26, 2013 09:11 AM
2001RR4.6
Off Topic
Jan 2, 2013 01:00 AM
Dan87GT
Dec 7, 2011 08:14 PM
garywinans
Jul 27, 2007 08:13 AM
