2001 Disco II front noise - Bearing?
New noise folks! I have noticed some metal noise on low speed, when acceleration around 15-30mile/hrs. once over 30 mi/hrs. there is no noise.
I had an accident and was a good hit one the right wheel, had to replace the rim and Drag bar. I had the shop checked under. There were no other visible damages.
My question: can this sound be from the Bearing? Do you recommend replacing the bearing? what is the best way to check the bearings? And what are the spec for these bearings? where would I find them?
This may not be bearing but if I open I may as well replace them just to eliminate the possibility.
Thanks for your help
Thanks Mike. No wonder I could not find just the bearings!
Front Break pads are good. You have a point there - I need to open and check.
This weekend hopefully I can dedicate some time. I have too many pesky issues and not enough time!
Well Christmas Break is coming. I may be in war path with the Disco. to fix all.
Sorry, I checked the Advance Auto site for front wheel bearing and it produced a T-37 bearing, can't trust those computer weasels....
Here's something close to the right part http://www.carparts.com/details/Land...-1597338986583
