2001 Disco light grinding after rear axle conversion
Old May 18, 2016 | 09:56 PM
dinava's Avatar
7th Gear
Default 2001 Disco light grinding after rear axle conversion
I have a 2001 Disco 2. I converted the rear axle to a u joint axle that I got from a 1998 discovery. I used the flange off the 98 as well. I put in the spacer recommended by atlantic british as well as a new oil seal. It drives much better, but I get a light grinding over about 30 mph from the rear or middle. At first I thought it might be the dust cover on the flange because it was loose. I put the dust cover from my 3 bolt flange on and it was tight. The sound still occurs. It goes away when I pull my ebrake even just a little or when I'm accelerating. It only occurs when I'm coasting. My suspicion is a bear (but why would it coincide with this modification) or my parking brake. Any ideas to diagnose or tips as to what it might be? The dust shield appears to be tight now but I could take it off and run it without that to see if it changes anything. Forgot to mention I have just under 2 inches of lift but it has never made noise before.
Last edited by dinava; May 18, 2016 at 10:11 PM. Reason: My own scattered thoughts
dinava
May 24, 2016 06:12 AM
Stuart Cruickshanks
Dec 26, 2012 07:07 PM
cationmoted
Oct 19, 2012 07:39 AM
callmehero
Mar 6, 2012 03:34 PM
khandrh
Aug 8, 2007 08:17 AM
