2001 Disco SII - Service Engine Light
Old Jan 27, 2012 | 04:40 AM
Another way to listen for a vac leak is to obstruct the air intake fully, which will shoot the vac pressure up, and make leak produce more sound. Also see attached for the oil breather system, clean item 10, if obstructed can cause strange problems. And check both hoses used in this system.
File Type: pdf
Old Jan 27, 2012 | 09:51 AM
You do not want to take the truck to a shop, send me your number and I'll call you and try to walk you thru what to check/do next.
Old Feb 15, 2012 | 01:45 PM
dgi 07's Avatar
Lean condition code on 1 bank? And you purchased all that stuff. Thas funny. Take the truck to a mechanic with a smoke machine and have him smoke your intake and exhaust. He should be able to.find it within a few minutes.
jh063078
Mar 21, 2008 10:19 PM
Cdixon1987
Oct 14, 2007 02:25 PM
CPDieker
Oct 17, 2006 03:28 PM
CPDieker
Sep 25, 2006 08:37 PM
CPDieker
Jul 10, 2006 06:30 PM
