2001 Discovery 2 Runnign Rough
I have a 2001 Discovery 2 that is running rough. over the past few years I have replaced the head gaskets, timeing chain, rear diff and the trans.Just this weekend I replaced the plugs, wire and coils. I am getting a shaking when I drive about 15-20 mph and again when I go over 75. I do not believe it is the tires because it goes away around 40 - 50 mph. Any help would be great.
A. Front propshaft, if still the oem style, is about to snap and tear into transmission. Inspect - if the double joint end has no grease fittings, or if they have not been greased (like every oil change), there is a rebuild article in the tech area (under $100 parts), or there are aftermarket shafts.
B. Rubber rotoflex coupling at rear shaft have tears?
and for those needing it the link to the tech area for propshaft rebuild is
https://landroverforums.com/forum/ge...rebuild-29302/
