2001 Discovery 2 Runnign Rough
Old May 6, 2013 | 09:28 AM
bcasey's Avatar
7th Gear
Default 2001 Discovery 2 Runnign Rough
I have a 2001 Discovery 2 that is running rough. over the past few years I have replaced the head gaskets, timeing chain, rear diff and the trans.Just this weekend I replaced the plugs, wire and coils. I am getting a shaking when I drive about 15-20 mph and again when I go over 75. I do not believe it is the tires because it goes away around 40 - 50 mph. Any help would be great.
Old May 6, 2013 | 09:43 AM
A. Front propshaft, if still the oem style, is about to snap and tear into transmission. Inspect - if the double joint end has no grease fittings, or if they have not been greased (like every oil change), there is a rebuild article in the tech area (under $100 parts), or there are aftermarket shafts.
B. Rubber rotoflex coupling at rear shaft have tears?
Old May 6, 2013 | 11:21 AM
bcasey's Avatar
7th Gear
Thanks for the tip, I am having a hard time finding the tech section to rebuild. Any direction you can provide would be great.
Old May 11, 2013 | 03:12 PM
bcasey's Avatar
7th Gear
Thanks for the tip. That was the issue! Running smooth now.
Old May 11, 2013 | 09:33 PM
jfall's Avatar
I don't drive my 2001 D2 over 60 MPH anymore - period.
Saves gas and I figure wear and tear.
Old May 11, 2013 | 10:35 PM
captain203's Avatar
what was your issue...A or B
Old May 11, 2013 | 10:49 PM
and for those needing it the link to the tech area for propshaft rebuild is
https://landroverforums.com/forum/ge...rebuild-29302/
Old May 13, 2013 | 07:22 PM
bcasey's Avatar
7th Gear
The issue was A. Two universal joints on the front shaft were bad. I replaced them all and also replaced the rubber coupling while I had it apart.
Old May 13, 2013 | 08:14 PM
captain203's Avatar
thanks for clarifying the issue had me wondering. Dose anyone know if you can drive a D2 with the front shaft out?
Old May 13, 2013 | 08:16 PM
If you can lock the CDL (with wrench on the spud or with a shifter) then yes
