2001 Discovery II LE - creeping temp guage
Old 07-01-2012 | 05:42 AM
x2 on the blockge in radiator (fins or internal) - the fan clutch face need to heat to about 180F to fully engage.
  #22
Old 07-02-2012 | 02:24 PM
NC1165's Avatar
7th Gear
Originally Posted by Disco Mike
Would you pay attention and quit guessing, I suggested your clutch, told you how to check it and you haven't done it as you were told. Do it and reply back. As for what your mechanic says, he is as already mentioned, a fool.
I did check the fan clutch before and after, as you suggested. Thank you. It is functioning as it should according to your description.
One of my concerns was to make sure that a shop doesn't sell me something I don't need. Now that I know what isn't broken, I had another mechanic look at it (on good reference) and he found a large calcium build-up in the radiator. Since the radiator is <6 months old, he is pulling it out and going to give it a flush treatment off of the engine and replace the thermostat.
Thanks for all the good help and tips to everyone.
  #23
Old 07-02-2012 | 02:31 PM
jfall's Avatar
Where do you live?
You should fill the radiator yourself with ONLY distilled water.
Or put in premix Coolant.
Sounds like someone put WELL WATER into your coolant system when it was done before.
That's a no no.
Hard water has high concentrations of calcium carbonate
2Discos
09-09-2013 04:23 PM
b c
01-19-2012 08:49 PM
duclover
05-23-2010 04:44 PM
rykrover
03-01-2010 06:24 PM
vinvelasco
08-17-2008 07:47 AM
Quick Reply: 2001 Discovery II LE - creeping temp guage
