2001 SE7 Air Suspension
Old Dec 13, 2010 | 03:25 PM
bjf123's Avatar
7th Gear
Default 2001 SE7 Air Suspension
We've got an '01 SE7 with about 110,000 miles that we bought back in the Spring. The rear air suspension is inconsistently leaking. Every morning, the back end is sitting low, but when you start it up, it usually pops back up fairly quickly. The problem is some days it will stay inflated and function properly. Other days, it will slowly leak out to the point of every little bump being painful. It doesn't seem to be temperature or weather dependent. Any ideas? How expensive of a repair is it? I'm not handy, so it's nothing I would ever attempt myself.
Old Dec 13, 2010 | 03:35 PM
DiscoIIBrandon's Avatar
Most likely leaky air bags, either 1 or both. They are rubber and all eventually leak. You can either get replacement bags (recommended to do both at the same time) - I recommend BP of Utah has the Arnott (lifetime warrenty) bags on sale for $115 each.
Or, you can convert to coils. Conversion kits are usually around $250.
Just make sure you know for sure before throwing money at it, I'm NO expert. You can spray soapy water on the bags when stressed and if it bubbles...you've got a leak. Can be tough to find though, mine's down at the fold.
I'm about to replace my air springs, and it seems quite simple. I've heard guys say from 1/2 an hour to an hour. Doing the conversion is more involved and opinions vary on if to do it and why. Its my wife's rig and won't be off-road so I'm replacing the air springs. Good Luck.
Old Dec 13, 2010 | 03:45 PM
bjf123's Avatar
7th Gear
Thanks for the quick reply. Some friends who are big into Rovers told us about a local garage that specializes in Rovers. Maybe I'll give them a call to see what they might charge to take a look and if that's all it is, repair it.
TRIARII
Jun 30, 2022 09:48 AM
DS24.Low
Jun 20, 2018 12:58 PM
ljdiscovery
Feb 13, 2016 11:21 PM
fastrx7man
Jan 28, 2012 12:49 PM
CANAMDiscovery
Apr 29, 2009 12:16 AM
