2002, 2003, 2004 Discovery
Why don't you tell us what you are planning on doing with a Disco, would make a difference on what you should buy.
Also what ever you get serious on have a pre-purchase inspection done by a good Rover mechanic, will save you a lot of money in the long run. Also plane on having the front drive shaft rebuilt and a major service, costing around $1000 retail.
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
on
Yesterday I rebuilt my front driveshaft on my 03 disco for around $70, the cost of 3 u joints with grease fittings. The CV joint center ball was good, just cleaned and greased the bearings. So, if you do your own work, you can save a lot of money. The dealer quoted me $1000 for a drive shaft, or around $300 from a drive shaft shop. ![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
Now I found that Toddco has the part for about $30 (ordered the part).
Land Rover Driveshafts
So, I will take it apart and replace it in the fall. I'm tired of working in 100+ degree heat.
I was not recommending that others skip it, I has just trying to give an idea of the money that can be saved by doing your own work.
Thanks for the advice.
I hate it when you call the dealer for a $50 part, and the response is "That's not available, but I can sell you the whole assembly for $1000."
jaysan21
03-12-2014 12:59 PM
jaysan21
03-11-2014 06:51 PM
spw0440
05-29-2011 07:23 PM
moocowman
11-29-2009 05:43 AM
moocowman
11-29-2009 04:18 AM
