2002, 2003, 2004 Discovery
Old Jul 30, 2011 | 04:43 PM
uglysteve's Avatar
Originally Posted by Disco Mike
Why don't you tell us what you are planning on doing with a Disco, would make a difference on what you should buy.
Also what ever you get serious on have a pre-purchase inspection done by a good Rover mechanic, will save you a lot of money in the long run. Also plane on having the front drive shaft rebuilt and a major service, costing around $1000 retail.
Yesterday I rebuilt my front driveshaft on my 03 disco for around $70, the cost of 3 u joints with grease fittings. The CV joint center ball was good, just cleaned and greased the bearings. So, if you do your own work, you can save a lot of money. The dealer quoted me $1000 for a drive shaft, or around $300 from a drive shaft shop.
Old Jul 30, 2011 | 07:08 PM
ringerso's Avatar
Now that's funny!
Old Jul 30, 2011 | 08:32 PM
You never rebuild a double cardon without replacing the centering ball, be ready for it to fail real soon, not a wise thing to suggest to anyone else to do.
Old Jul 31, 2011 | 09:03 AM
uglysteve's Avatar
I would have replaced it, but I could not find the parts for the ball. The dealer and the aftermarket suppliers that I checked did not have it. The grease in the bearing still looked new, light brown and clear. The only reason my u joint failed was lack of grease. It was dry. The other joints in the shaft still had grease. The ball was not worn out. I took out all the bearings, cleaned them, and greased them. It should be good for a while.
Now I found that Toddco has the part for about $30 (ordered the part).
Land Rover Driveshafts
So, I will take it apart and replace it in the fall. I'm tired of working in 100+ degree heat.
I was not recommending that others skip it, I has just trying to give an idea of the money that can be saved by doing your own work.
Thanks for the advice.
I hate it when you call the dealer for a $50 part, and the response is "That's not available, but I can sell you the whole assembly for $1000."
jaysan21
Mar 12, 2014 12:59 PM
jaysan21
Mar 11, 2014 06:51 PM
spw0440
May 29, 2011 07:23 PM
moocowman
Nov 29, 2009 05:43 AM
moocowman
Nov 29, 2009 04:18 AM
