2002 DII misfire
Old May 8, 2011 | 10:14 PM
kjgale's Avatar
8th Gear
Question 2002 DII misfire
Hi All,
Question. I am getting codes on my truck (p301 & p306) for misfiring. I was wondering in anyones experience, could this be just the wires and plugs, or is it more likely the coil pack?
The wires are original, the plugs replaced about 30k ago.
Thanks for all your help.
K
Old May 9, 2011 | 05:26 AM
Bundu's Avatar
Banned
Why does everyone assume coil packs first?
Replace the wires - they will most likely be the cause and they are much cheaper than new coil packs.
Go get some 8mm wires at Kingsborne Kingsborne Wire Werks Inc - Spark plug wires, Automotive, RV, Motorcycle, Marine, Racing, Industry
Old May 9, 2011 | 05:56 AM
kjgale's Avatar
8th Gear
Ok, I plan on trying to replace the wires and plugs. What wire set and spark plug does everyone recommend?
Bundu, the Kingsborne wires seem like a great deal at $30 versus the Magnecor set that run about $95. Are they comparable?
Thanks again.
K
Old May 9, 2011 | 06:05 AM
Bundu's Avatar
Banned
Many people are running Kingsborne wires, including myself. I have not heard of any complaints about them. You can also look at STI wires.
Old May 9, 2011 | 10:19 AM
agthird's Avatar
I'm running the cheapo autolites and like them...make sure the gap on the plugs is right..
Old May 18, 2011 | 04:14 PM
kjgale's Avatar
8th Gear
Default Update
My brother and I(more my brother then me ) replaced the wires and spark plugs yesterday. Used the step by step instructions posted in the sticky and had the job done in about 3 hours or so. Small hands would be a big help, unfortunately neither of us have them.
Used the Kinsbourne 8mm wires as recommended. Running like a champ and no codes.
Thanks for all the help,
K
p.s. I plan on doing some of the other recommended tune up items Disco Mike talks about, will post results.
Gromeo
Jan 24, 2013 03:41 PM
Lonewolf_ky
Freelander
Oct 23, 2010 08:55 AM
DiscoNoisebox
Apr 20, 2009 08:53 PM
mconroy
Jun 24, 2007 05:37 PM
justfred
Aug 24, 2006 05:02 PM
