2002 Disco Low Oil Pressure
Hey Everyone,
I'm in the middle of a Disco 2 build and I'm trying to troubleshoot a low oil pressure issue. To summarize I bought a 2002 Disco for cheap, drove it maybe 200 miles of highway driving home without issue. Next day I try to drive it in the city and it immediately overheats; still no check oil or engine light. I take it apart and the heads are a mess, but the rest of the engine internals look good. I do some part replacement, fire it up, and it sounds great. Oil light flickers on and off at hot and cold idle which is new, so I just put a cheap Harbor Freight gauge on it, here are the reading I got:
Initial startup: 32 PSI
Initial Cold Idle (1k RPM): 8 PSI
Steady Cold Idle (750 RPM) 6 PSI
2K RPM Cold: 16 PSI
Steady Hot Idle (700 RPM) 7 PSI
2K RPM Hot: 14 PSI
Engine has 82k on it, and is now running Shell Rotella 15w40 T4 with a Fram Filter. Vehicle hasn't left the driveway yet, put plan was to run crap filter and this oil for 50 miles or so, and then run Rotella 15w40 T6 and a better filter.
Brief Summary of the work I've done is:
Head Gasket Replacement w/ New Bolts
Heads Machined & Tested
New Complete Rocker Assemblies
New Lifters
New Push Rods
New Water Pump
New Plugs & Wires
New Oil Pump (Old Pump Looked Fine)
New Timing Gear & Chain
New Main Seal
New Plugs & Wires
New 180 Thermostat
Cleaned Timing Cover
Cleaned Oil Passages in Block (Very Clean)
Cleaned Oil Pickup (Not clogged) w/ New O-Ring
Cleaned Oil Pan (Some Sludge at Bottom)
Misc Gaskets Replaced During Head Job
The thread can be found here: https://landroverforums.com/forum/bu...ild-nh-101158/
But to generalize I started with this:
And brought it to this:
Anyone have suggestions? What are the minimum PSI requirement I should be looking with a Disco of this age and miles? Appreciate the help.
Oh; and it doesn't overheat now.
2K RPM Cold: 16 PSI
2K RPM Hot: 14 PSI
New Lifters
New Push Rods
New Water Pump
New Plugs & Wires
New Main Seal
New Plugs & Wires
New 180 Thermostat
Well you could try a new oil pressure switch, but those readings are pretty low and 7/8psi is when the oil light comes on. I would say you either have a walked cam bearing or worn main bearings.
When the light flickers does the engine sound any different?
I just dropped the pan and pulled the timing cover off. The oil pump gear is not broken, and the oil pickup tube has a good o-ring seal. I’ll take some pictures of what I can see tomorrow as far as cam bearings. Not too sure what I’m looking for though. Thanks for the help all.
